Yuko04
"SquareBODluvr"
MN
Started "wire wheeling" the frame, brake calipers and bottom side of the front fenders.
Wire wheeling will take at least 2 weeks. Then then I will spray the frame with rubber undercoat as the underside of the front fenders will be the same.
Calipers will be Cherry red... Gotta keep myself busy in this -30 below weather.:D
Kman
Southern California
Had the transmission serviced (pan dropped, new filter and 5 quarts of fluid). Replaced both fog lights since the lens were missing with TYC stock ones. Ended taking them apart and mounting the new lights to the stock brackets. And I washed and waxed the Tahoe this past weekend. Of course it poured all day today.
Probably drain the radiator and add fresh fluid this weekend.
Kman
Southern California
Drained radiator and refilled with Prestone DEXCOOL. Coolant was changed at 49,000 miles ago when the water pump was replaced but I wanted to change it again. Coolant actually looked really good.
I took the overflow tank out and cleaned it all up. Looks good.
Red_Raider
Derby, Kansas
Tried to install the drop kit, but need some bolts for the spindle to hub assembly before I can do it. So I just did my dash and interior LED upgrade. Man does it make a difference!
Kman
Southern California
Cleaning out the inside. Wiped the interior down with some quick detailer. Cleaned the leather seats. Looks good again.
Lfryklu
