CaptainAmerica1
Z71 springs and rear sway bar end links.
Plugs and wires too.
I believe the entire GMT900 series you need to buy the entire assembly. I had to do this on my ‘08 2500HD. IIRC it was about $75 for the bottom spring one. They all go bad on these GMT900’s unless you’re aggressive with the lube.they must have changed the design on my 2012 the bottom hinge does not appear to be easily serviceable, the hinge would need to be replaced or removed and some parts punched out the fulcrum bolt is pressed in and has a mushroom head
How did you install them wrong?Yesterday i installed the front struts wrong.![]()
Today I fixed that.
Sent from my SM-N950U using Tapatalk
I just did this with the 12$ ebay one from China. Works fine.I’d definitely go OEM, unless this seems like a 5-minute job, then go for the Dorman part. [emoji16][emoji106]
Probably last 6 months.I just did this with the 12$ ebay one from China. Works fine.
Sent from my SM-G973U1 using Tapatalk
Had too many ring's under the lower perch. Had them set for stock height. Misunderstanding of the instructions.How did you install them wrong?
Today I fixed that.
Instructions were unclear. Got dick stuck in ceiling fan.I’m assuming right on the left side, left on the right side?
