what are you going to do with the old one. if it's the small 2 wire plug one and still works. depending on how horrible shipping is, I might buy it from you for a project I'm playing with in hptuners.
It's whatever is stock on an '08 LMG in an LTZ. It's the DR44 (145A). I know it's a direct-fit upgrade on the S-series vehicles! I would say that I'd like to keep it as a backup. But, it'd likely sit on a shelf and eventually get scrapped. It seems to work fine although I can't verify its output and I'm 100% sure my lights dimming is due to my aged and semi-abused battery. I'm just wanting a fresh alt and like to upgrade when I replace stuff. What are you doing in HPT that would warrant having this alt.?
if you're interested in selling it, let me know.
I wouldn't sell it. I've had fellow TYF brethren contribute to my experiments so I'm happy for the opportunity to pay it forward. Just cover shipping and it's yours. But, lemme get my new one installed first. I might need the pulley from it if the new one won't work. PM me.
j91z28d1
well it's not for my yukon, since that doesn't have a alternator at all, so I'd feel better tossing you something atleast. but I also understand keeping one of a shelf and I should probably just do what you did and pick up a 200amp off ebay too. if it doesn't work I'm sure I can sell it on here for about what I paid.
I'm going to try and use it on a 08 c6 corvette. the ones corvettes use are large case oddball. the ecm doesn't send a pwm signal to it to control voltage, just a on off trigger wire. the stock ones charge badly at idle and anything aftermarket is super expensive.
I have an adapter from ict, if that I hope I can use to make it fit, I've found a drop down box in hptuners for alt control. I enabled that and put some random numbers in it and got a pwm signal out on my little pocket o scope. there's a thread on ls1 tech for the camaro guys about what hz to send into a 2 wire to get what output voltage. if I can get the smaller body alt to physically fit, and find the right numbers to put into hp to target 13.8v. it would be a cost effective option for a 200amp alt like you just got off eBay without having to buy a 600 plus aftermarket alt just to get the extra 20 or so amps needed at idle and not explode at high rpm from a smaller pulley. which is what I have now, just a touch over driven and idled up a 100rpm, but it's still iffy on 100deg days idling in traffic with max ac.
so yeah, it's a project I put on the back burner at the end of last summer but summer is about to hit hard here soon again.
j91z28d1
New 140mph blades and a new rear passenger window switch
it's amazing how much they want for wipers these days. I walked in once to get some on the ride home on my car that has 24in wipers. I was in shock when 2 would be 50$. they said it's a dollar an inch these days. I drove home with bad wipers lol.
if you have the kind you can pop off the end, like most oem blades. I've found you can still buy the rubber itself super cheap off ebay. like 3 sets for 5$ shipped. just take a month to ship, so buy like 20$ a year worth. they look identical to the rubber in auto parts store blades. work great and I find myself swapping them much more often because of the price. so they work better for me lol. I have 4 cars to keep blades fresh on and tx sun to eat them up in no time and then random violent storms out of nowhere to drive thru.
pwtr02ss
Tennessee
I could take a video, but all you'd see is the tach sharply drop. Maybe even hear the engine's hum change. Can't convey the sudden "bog" feeling when it locks.
That's how they work, at least both of mine. It's not violent in the way of slamming, it's just sudden lock and unlock. As per a super smart man meats, aftermarket toque converters don't like to ramp in the lock up. They need to either lock or unlock. None of the easing into it
pwtr02ss
Tennessee
Amazon also has them as well.
For the record, I've only replaced the rubber part on Stephs accord and my Yukon with oem pieces since they were new. They aren't more than $20 for both sides and the oem "wiper" assembly is nicer than the replacement parts. The Honda is cheaper than gm but that's to be expected
I dig it! I'm all for experimenting and finding cost-effective ways, especially with OE parts. My new alt should be in tomorrow and I plan to install it this weekend. I don't see how I wouldn't be able to if it's a direct plug-and-play swap. That's about a 30-minute project including taking time to stare at it and wonder if I should paint it.
brian70068
