Charlie207
LFOD, New Hampshire
It’s buried in my cam swap thread somewhere, but I totally forgot about it until I saw your post just now.
Did you have to swap the two outer wires on the 3-wire connector, or was it good to go from the start?
I've been reading that there is a difference in signal pin location from the 5 to 3 wire harnesses.
Geotrash
Dave
Richmond, VA
I did not. The harness I needed came with the VVT delete kit I bought, and no mods were needed in my case. But mine is also a different engine - 2012 6.2L so I don't know if that makes a difference.
Fless
Super Moderator
Elev 5,280
I noticed the same thing when I changed out the cushion and leather in my ‘07, but I like it. My cushion was from the seat shop as well.
x3 when I changed my seat foam from The Seat Shop. Boosted me an inch or so and is firm but not hard.
Just Fishing
Can't fix stupid
Utah
I replaced my foam with "OEM" but it was white foam vs the OEM yellowish foam.
Not sure if it just turns Yellow with age, but it does seem to be different.
It has softened up with use, but it's still harder than the original on the passenger side.
my oem seat pad I bought is black foam
Charlie207
LFOD, New Hampshire
camshaft position sensor, that's the one right by the harmonic balancer check to be sure it is plugged in
It is.
I started with the vehicle loom (5-pin) harness > ICT 5pin to 3pin adapter > plugged into the sensor. No start - threw the code.
I then wired the loom > OEM crank sensor harness into the cam sensor. No start.
I'm swapping the sensor now.
quikdime
