newbie78
Does it stay the stay the same speed in idle no matter if hot or cold engine start or temp of the atmosphere?
Yep. Owned it for 3 weeks now and always idles at 1000 lowest 900+ I started it and drove it about 10 times total. The temp outside hasn't been below 70 the days I start it.
retorq
Kingman AZ
I liked my trailblazer wheel install, but something was just too plain. Grabbed a airbag from a 06 trailblazer, and changed out the covers. took all of 5 minutes, and looks a whole lot better!
Before
After
Shawn
Does the airbag still work??
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I forgot to ask when you put it in gear does it go down or does it stay the same? If it stays the same that it is possible it is working, partially anyways, and the problem might be elsewhere. If it goes down from the load of the tranny then you are still wanting to concentrate on the IAC valve. Try resetting it:
  1. Start the engine for 20 seconds .
  2. Turn OFF the ignition for 10 seconds .
  3. Start the engine.
  4. Check for the proper idle speed.
If still absolutely no change in rpm then replacement may be needed.
qukon 95
Some idiot broke my pass side rear door window and tried to get my 2 din radio out at my
Daughter job went and got the window $ 25.00 put it in and and adjusted my shock sensor
Now it chirps when tapping the windows. I'm going to look into putting interior sensors
In..
MC153
Installed my HID harness. Tried soldering a new fuse holder into it but the solder wouldn't stick to the wire for some reason. So I gave up and crimped the thing.
BirchyBoy
I found evidence of an oil leak. Now to figure out where it's coming from. Grrrrr.....,
wlivsey
