chaingun427
OBS Mad Scientist
Mooreland, OK
Now onto the rear hatch leaking. That has a pain in the butt.
I had to do mine not that long ago, they've made a few revisions to the parts numbers, and you might want to replace the strip above the main seal too
Sent from my SAMSUNG-SM-N920A using Tapatalk
Dneel81
OKC
Put the second set of spark plugs and wires in the truck for its 270,000 miles
Replaced the 2 lower O2 sensors got rid of my service engine light.
Oil change.
Replaced the 2nd set of ball joints on the truck(well 3rd if you count when I put the lowered control arms on)
Located the small leak in the exhaust
Fuel filter, had 120,000 miles on that.
Cleaned the K&N air cleaner.
Drove it 289 to Orlando, got 15.9 miles per gallon. A small improvement, cruising at 88 mph and really windy.
Seat of the pants it is peppy now. Got rid of rough idle and stutter it had developed.
I have a company vehicle and the wife has been driving the Tahoe. She has told me about the symptoms but as usual busy and did not think it was much of an issue. Well glad I jumped on it.
Interested in your fix of the rear hatch leaking...
98blackbell
FL
I replaced every rubber on the truck for upper hatch and bottom drop down door.
Still leaks on the passenger side starting half way down the side rubber then a water fall stream affect through the split. Will try making a post on what I try to fix. Its 41 degrees outside and way to cold to be using a water hose to find a leak.
GM iraqi
Today was valentines day so I washed my baby for three long hours
Then before I even take it for a spin it rained and goodbye for the 3 hours wash :sad72:
noJeepshere
Bountyfull, Utahrd
Replaced my broken backup lights with some brighter ones.
Old
New
sent from a slablet
chaingun427
OBS Mad Scientist
Mooreland, OK
Heads are back on and torqued, never going to trust a junkyard motor again
ezmoney1981
