SnowDrifter
- Joined
- Sep 5, 2016
- Posts
- 2,445
- Reaction score
- 2,688
What is even a flush. That term is thrown around so much.
View attachment 225747 I bought my 2004 Tahoe z71 4wd in October 2017 with 149k miles
Currently at 176k miles
It’s in the shop now to replace a leaking water pump
When I bought it, it had a bad oil pressure sending unit-had that replaced
Shortly after had a leaking rear pinion seal fixed
At 168k miles had both front hub bearings replaced as they started the helicopter sound
Recently had a cat that went bad and had the a/c serviced
Nothing too major and I switched to Mobil-1 high mileage 5w-30 ever since I got it and have kept up on oil changes every 5k miles
What can I expect going forward with the truck creeping up on 200k miles
It’s a daily driver of 60 miles a day so mileage adds up quick
It’s had a minor oil leak ever since I’ve got it. Having that looked into while it’s in the shop. Going to have them run the dye through it. Always kept an eye on the oil level. Takes about a quart, sometimes a little more between oil changes
Pan capacity is only around 3 quarts for a 11.2 quart system. Puts that around 27 percentFlush is hooking up a machine to pump fluid in , vacuum fluid out and removes ALL the old fluid.
A change is pull the pan and filter - only removes about 40-percent of old fluid.
Which machine? The one I use goes down the dipstick and drains/fills the pan a couple timesFlush is hooking up a machine to pump fluid in , vacuum fluid out and removes ALL the old fluid.
I don't know of any way to get all of the old oil out of a transmission, in particular, the torque converter doesn't have any way to be drained or pumped out. A flush on an automatic transmission is way oversold. Yes, you might use 13qt or whatever of new transmission fluid, but half or more of that new fluid will be thrown away and you'll still have old oil in your transmission.Flush is hooking up a machine to pump fluid in , vacuum fluid out and removes ALL the old fluid.
I'm at 195k (04 LT) and here's my all of a sudden list:
- new water pump
- new front brakes and rotors
- trans flush for towing
- new tires
- inner/outer tie rods (this month)
- JUST happened this week: knock sensor bank 2
- all new shocks and rear coils (this month)
Let me get to the point on a couple things
1. Torque converter isn't a closed system. Fluid runs though it from the oil pump in the trans. It absolutely has to, otherwise the thing would overheat and boil the fluid in very short order. Torque converter is the primary source of heat in an automatic trans
2. The whole bit about flushes vs. Changes is tiresome. Sure there are some power machines that hook up to the cooler lines, but even still, those are uncommon in my experience on account of the labor involved to use them. And even still, they pump fluid at low pressures, below 60 psi, which your transmission does anyway.
3. There's this odd double think bit on the forum where the preferred method of changing fluid is to remove the cooler line and start the car (which I disagree with) while simultaneously saying that doing the same thing with a machine which adds fluid at the same time do avoid running thr pan dry is bad
4. You don't need to get all the old fluid out. The system is not that sterile
5. If you ever find yourself at a point where you don't want to flush/change/drain/whatever nomenclature you want because of fear that sludge will be moved around, then I suggest you do some reading. Transmissions don't undergo any combustion and as such, do not form sludge. The only debris that can form in a transmission are wear metals, which will be attracted to magnets at the bottom of the pan, and clutch material, which will be suspended in the fluid. If you change your fluid and find that your trans is ******* up after, it's no fault of the fluid change/method, you'd just discovered that your trans was EOL and was set to blow up within the next couple thousand miles anyway. If your reason for changing fluid is because of poor shifting/slipping/etc, there's a good chance fluid won't help it on account of damage to the hard parts already being done
