SunlitComet
OBS Jedi-Do Good
Line 20 when attached to 21 should have vacuum on the side of line that attaches to solenoid you pictured tho it may be hard to feel with ahose of small diameter. DDid you do the volt test?
test that wire as soon as you can then.
With that line 20 connected to engine an water valve solenoid did you get a vacuum onthe hose that goes from solenoid to water valve? And what volvoltage did you get when the temp dial was set to max cold detent and a/c control on?
