Whats the best spark plug?
04SS99Denali
NY
stick with OEM ac delcos imo. ive changed my spark plugs in my NBS to NGK TR55 iridiums and i havnt seen even .1 mpg increase in the DTC
Glock 22
So for a 99' Tahoe 5.7L. What is the "Correct" gap for the use of NGK G-Power plugs?
mgiroua
Last year I bought some AC plugs for my Uplander and when I opened the box, they were actually NGK plugs with an AC number added. So, I bought NGK at half the price for my Yukon and they work fine. I'll second MrSmooth1031. Just my 5 cents.
LI99HOE
Top Notch Tech.
N.Y.
I installed Ac Delco 41-993's gapped @ .060. Originally did this one month ago and installed new AC Delco wires, cap, and rotor at the same time. After doing this I got the infamous P0306 code popping up occasionally under load/up hills.
Yesterday I pulled all the plugs, rechecked the gaps. Only one was gapped too far. I had a couple of the OEM spark plug wires come out of the boots...so I changed them with Bosch wires. I inspected the cap/rotor, and found that all of the terminals on the cap were corroded. Changed cap/rotor with Duralast Gold parts(brass terminals), and now the truck starts/idles/accelerates great.
Fingers crossed, but no code P0306...:rocking:
TTZ06
Houston, TX
Unless you are spraying or boosted, OEM plugs are all you would ever need.
LI99HOE
Top Notch Tech.
N.Y.
Very true TTZ06...... my point is..... beware OEM caps/rotor, and wires. That tune-up you just completed with them might actually be a tune-down :)
99Yuk
Northern Ontario, Canada
Actually it's not just OEM caps and rotors. I recently just did a 'tune down' when I installed my new MSD cap and rotor. They didn't make it a month before they had to be swapped out for AC Delco cap and rotor.
And worse, there's no way to tell before you install them...
LI99HOE
Top Notch Tech.
N.Y.
Wow 99Yuk.... I wouldn't have expected an MSD set to go bad so fast, especially since they offer brass terminals(and are a pretty penny).
Anyone ever try putting a bead of silicone grease or such where the cap meets up with the metal on the distributor, to prevent moisture from entering the cap, and destroying the contacts?
Tssonebay
