When replacing stock bags snowballs into a Long Travel '04 Denali
slow4dr
slow4dr
I haven't spent any time on the truck the last few months. Too many projects going at once.
I have kind of backed off the ledge on the rear suspension. I wanted to mount the 12" travel bypasses out back but I am just kind of over it right now. It would require completely new upper shock mounts and packaging will be a PITA. It had 10" reservoirs coilovers back there just with no coil springs. Those are now mounted on the front with coils. So I am thinking about just getting another set of 10" travel smooth body or maybe bypasses so that way they bolt right in.
I still need to figure out the front steering. Same thing here, just too much going on so i'll probably just order the Cognito steering fix. Then I can move forward with checking bump steer and actually finish up the inner tie rod (heims) mounts.
macking
