Bigkevschopshop
The more I do the math with the GVWR and how much we will be carrying, the more it seems it’s not really feasible. I only have around 500 lbs of hitch weight left over so that puts me at about 5000 max trailer weight, or 3500 dry weight if I leave the 1500lb margin for stuff in the trailer. And that’s with my kids only weighing 50lbs each right now.
Weight distribution hitch is included in the numbers?
WD hitch, trailer brake controller, you should pull 5k dry weight and all your gear/wife/kids with no problem with a 6.2.
Stock towing capacity for 6.2 is around 8k stock, do a few things and increase that and make it safer, the truck on flat ground will pull more than doing hills. If I can do 5k trailer no weight distribution hitch frequently with a 5.3 with another 1k in the back, you can dang sure do it with a 6.2
My burb loaded down like normal, 22' car hauler, 2500 dry weight, 3500 lb car on back... 12 mpg let it eat...
![IMG_1074[1].JPG IMG_1074[1].JPG](https://www.tahoeyukonforum.com/data/attachments/234/234779-c1195158c2c6eba97c47293668373786.jpg)
