driver side only for now, upper/lower cover with new bottom cushion. also need to clean up the head/arm rest and really clean that crusty belt.
View attachment 244642 View attachment 244646
You can use Scrubbing Bubbles bathroom cleaner on the rest of the seat to clean it. Use a short-bristle brush and wipe up the loosened grime with a clean rag, do it in small areas. It will look almost new. Just don’t use it on a regular basis, once every few years is ok.
TheAutumnWind
I've done this before scrubbing bubbles works.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Did you use the same old foam? Leather or vinyl? You did the install yourself?
i also replaced the bottom foam cushion, i went for the leather a lil' more but worth it. i have heard that vinyl is a no no. i got one of the tech from work to do it, he said it was a pain in the ass to do. good material, only thing is you have to cut your own holes for the bottom switches and air bag on the upper cover also for the belt.
Came out great.
Sam Harris
Replaced the bright af reverse LEDs I got on Amazon with the JDM Astars. It’s full sun, but you can still see the difference. Holy crap, can’t wait to see these at night. Hope they’re not too bright for the reverse camera to handle.
Tjf2222
