blueinkd
That be a question for someone else. I saw a thread on here about someone having wired the same setup. So at the rate they are stealing these trucks in my area, I decided to do the same. Even with alarms they take them. This cost me less than $20, works well so far. Pull that fuse and truck just won't start. Its all I know. I just bought it from my mom so I been cleaning it up and tinkering with it. Fixed the AC last week. Just needed a new accumulator and O-rings, installed a new vent solenoid and had front seats refreshed with new leather. Just an extra vehicle to play with.
05Single
afraid of the dark
Wired up a kill switch from the crank fuse as seen on another thread. Cost me less than $20 for supplies and works like a charm. Took about an hour with careful planning and mounting of the switch in the cubby.
View attachment 255839 View attachment 255840
good idea but I wouldn't have put it in the fuse box i would have hid it somewhere else because these trucks are not easy to steal, if you know what you are doing and presuming you broke the ignition switch and the security system is doing it's thing then you would have to power up the fuel pump in which case the relay is right there in the fuse box
diLucca
Bratislava, SLOVAKIA
Sam Harris
Finally wore out the old tires enough I didn’t feel too bad getting the new ones. Went from a 265/65 16 to these 2015 Yukon 18’s, and 285/60 18. I think they fit perfectly in there. Stance even looks pretty good, but I know some will say time for a drop. [emoji16]
Now I can get those calipers cleaned up (thanks @Rocket Man), and order the pads and rotors.. next is the NNBS brake upgrade with stainless lines.
Silentnight008
