Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
I love sleepers. Both of you guys meet that criteria. Love both of your rides
2 snaps :D
pretty much... i can **** around all i want. if i dont want to, i just roll the windows up and do the speed limit and it passes for a nearly stock truck with some exhaust.
turbo drain was still leaking, after the 3rd fitting. so i threw the trusty ict billet fitting back on which is actually a block with a 3/4" npt with a 3" extension threaded into it and a paper gasket.
ICT Billet stuff is nothing but quality. I have a few pieces of theirs.
randeez
randeez
south florida
Yep and not retarded expensive either is the nice part.
Track last night, same old slow junk. Before I even made a pass the cam position sensor came unplugged at the bottom of the front cover, tried to fix at track, got it together but wasn't sure if it got all the way together.couple nice burns to show for it above my thumb. Didn't want to risk is coming back apart wot. Was good enough to get home, jack up tywrapped the two together and went back to track. Runs 10.7s all day.
randeez
randeez
south florida
i do a few transbrake+2step launches and i kill the turbo :banghead:
unrelated im pretty sure, but after another oil drain fitting, this turbo is just leaking oil between the center section and the exhaust side. only does it under boost (which is also when i have high oil pressure 85psi+) but shit is vented with 2-10an on valve covers. i emailed them to see if they repair or will sell me parts to rebuild it.
guess ill throw the 80mm back on in the mean time to putt putt around
Lol, putt putt with the 80 mm!
Stevemo70
