2008 Ford Crown Victoria P71 SAP
95escahoe
95escahoe
Been debating throwing on Mustang wheels for awhile so around Christmas there was a bunch of sales so snagged these reproduction Bullitt wheels 17x9 up from 17x10.5 in the rear. Going to wait till spring to throw them on.
89Suburban
Bull in the china shop
SE PA
Actually a bunch so I got that 3 head upper Inner Edge installed.
View attachment 389848View attachment 389847
Then I finally installed that console I got a few months back and switched out the siren controller and light switches for one unit a Touchmaster Delta, all the lights are are on the slide switch everything comes on on the last setting and all the buttons are available for more lights down the road possibly.
Very nice!
95escahoe
95escahoe
Those bolts in the roof how was that construed? Are there factory inserts?
So there’s two push in clips that hold the headliner up in the rear so you pop those out and drill out the hole and make it bigger then you pop in a jam nut in either hole there’s a special tool they make to install it, it’s basically a flat piece of metal with a hole in it you put the bolt through then put it in the hole and tighten it down which causes the back side to crush to the back side of the roof and gives the bolt a nice sturdy mounting point.
I see you have the built in fire suppression system. Pretty cool. Is it still hooked up?
I've also been looking for some used Mustang rims, but haven't had any luck.
95escahoe
95escahoe
It was till I threw the cat-back on the bigger exhaust wouldn’t clear the tanks so had to remove them, been trying to sell the complete system but nobody wants it I was looking for used wheels for awhile but they pretty much all needed tires or the rims had issues so just bit the bullet and bought new ones
The tanks are mounted under the car? I thought they were mounted in the trunk.
shadowid60
