2011 Chevy Tahoe overhaul needed?
Marky Dissod
Do you recommend stopping the AFM on my 2011 Tahoe? I’ve always thought that would be the big worry for my used Tahoe but it’s working fine.
YES (for a decade, give or take. Please pass it on, be better than those who failed to warn you previously).
It works fine, for a while, til it doesn't. Eventually,
*the part-time cylinder bores / rings wear worse than the full-time cylinders, increasing oil consumption and lowering MpGs even with V4 mode in working order
*the two-mode lifters are not as durable / long lived as the simpler lifters; the two-mode lifters tend to fail sooner than the simpler ones -
when they fail, it's not like you still have a V4 that still works, you have an engine that needs fixing or replacing
*V4 mode is also responsible for shortening the life of the torque converter clutch. When the TCC fails, it usually takes out the entire 6L80 with it.
Even if you use the best oil filtration, the best motor oil, and change them 2x as often as GM recommends,
and you put off the two-mode lifter failure til you get rid of the vehicle, your TCC is still gonna fail sooner.
TLDR: If you can't afford to physically delete the V4 mode hardware, at least disable it at your first opportunity.
rdezs
Oil seals that are seeping isn't much to worry about. When it leaves a puddle under the vehicle, then you can worry. I'd recommend using one of the full synthetic motor oils that stay high mileage on the label. Such as Valvoline or mobile one both have a version. They contain seal conditioners that helps soften seals that have become hard with age.... And do help minor seeping.
The AFM.... It's never too late to turn it off. You can buy a device and plug it into the diagnostic port below your steering wheel and to the left..... Or you can buy a programmer such as the Diablo sport predator and actually turn it off in the ECM..... Ideally you would turn it off in the ECM, and do a full physical delete of the components. Cost-effective if you work on your own vehicles, probably expensive to have somebody do it for you. If that's your situation, get the one that just plugs into the diagnostic port.
Transfer case seems to be the main concern with metal shavings. I'd suggest changing the fluid again in a couple weeks, but find a different service provider. See what they say after they drain it. And as usual, be wary of expensive recommendations to fix something. Always get a second opinion.
j91z28d1
limit slip additive in the front and rear differential?
I wouldn't put a lot stock in what that place says.
for reference, this was my transfer case drain plug when I got mine at 135k fluid was pretty black. it's now 166k and never shown any problem. I did change the fluid a 2nd time and there was no metal and fluid was clean.
if it's not worst than this and looks good the next time 5 - 10k later. I wooldnt worry about it until you see signs of failure
The Grey Beast
The Grey Beast
Thank you all. Very good posts. I just ordered the Diablo and it should arrive 21 Feb. just put a new set of Toyo Tires Open country AT III’s look great. Breaks are next have not done them since purchased used May 23. Thank you all for the distinct and accurate information. When I end up doing more things on the Tahoe I post the results.
Thank you.
Ken
Dustin Jackson
@The Grey Beast Yes the transfer case is separate from the engine and it doesn’t sound like you are leaking much engine oil either.
If the Tahoe still moves down the road I don’t see a problem, keep the fluids clean until something breaks and then fix it but no point in spending money if the thing still drives down the road.
ivin74
05 NBS Nali
Htown, Texas
They also stated my engine seals are weeping perhaps leaking. I had 3k miles on last oil change and half a quart low of oil. What would be your next move. The engine has 179k miles runs great.
I’m looking to price out and overhaul of the engine.
These engines are known for the seals to go out after 120k miles. Did the shop tell you what seals are leaking?
Most common failures
Valve cover gasket
Rear main seal
Valley cover gaskets
Oil pan gasket
Oil cooler gasket
I have seen these LS engines go past 300k miles with no overhauls. I suggest replace those seals and you are good for another 120k miles.
I would not be to worried about the oil consumption. Like others stated verify what valve cover you have. Replace it if it's not the newest version.
tom3
When doing the brakes check the slider pins on the calipers. Pull the pins out, clean and regrease with some good brake safe lube. You'd be surprised how those can get rusted and seize up tight.
The Grey Beast
The Grey Beast
Thank you both I will reference these post in the future. Thank you
The Grey Beast
The Grey Beast
Hi to all.
So I purchased the Diablo sprint and plugged it in. It flashes red and then one red light. I’m assuming this is some kind iof error. However the AFM seems to be disabled. Go to work later and will drive it in the hwy and will see. Any thoughts on what is going on?
Thank you ahead of time.
Ken
Jmartin1635
