Leaking oil on a 2011 Chevy Tahoe
The Grey Beast
The Grey Beast
Hundred bucks says it's the little oil cooler block-off plate/oil cooler line manifold right above the oil filter. They all leak there eventually. If it's the block-off plate, replace with an ICT Billet plate with the matcing o-ring seal. If it's the cooler lines, replace the gasket with OEM and give it the thinnest coating of black permatex. Let the permatex sit overnight to cure fully before starting. Be very vigilant of the torque spec on those bolts.
I was rooting for you and your ideas were spot on generally. It was a leak caused by a badly screwed on oil filter.
I’m curious though Chevy dealer recommended an oiler cooler line replacement not related to my initial visit. I’m not too familiar with parts you are discussing but if you have pics with comments it would be appreciated. I’m having the transmission line replaced. The exhaust bolt broke off and of course the oil cooler line eventually needs replacement.
Thank you.
Ken
Airman68
Kaukauna, WI
My block off plate was leaking at one time but fixed. Now it only leaks when the truck is parked with the front uphill. When I park with the truck downhill, no leaks. Go figure.
Geotrash
Dave
Richmond, VA
Thank you.
Ken
I actually did document the oil cooler line replacement here. I replaced the left front wheel hub and the drivers side motor mount at the same time. https://www.tahoeyukonforum.com/thr...ahoe-yukon-today.44151/page-4276#post-1771420
Jmartin1635
