2015 Yukon HID Conversion from The Retrofit Source
twhitechurch
How can you connect canbus and relays???
Sent from my SM-N900V using Tapatalk
08grey
You only need to do one side. Plug the cancelor into light bulb harness then Into signal input on relay harness.
08grey
Make sure positive and negative are correctly lined up. Or POP.
S
Steve1081
Update: I am having an intermittent issue with the driver side bulb firing. I would recommend the relay harness to anyone doing this. I am going to email TRS and see what they recommend.
Tylus
South GA
Looks awesome. Can you update if the relay fixed the issue or if the Canbus is all you need?
S
Steve1081
I am still just running the Canbus with no relay. Both of the lights have been firing pretty reliably lately; but it still isn't 100%. Maybe 5% of the time one of the lights doesn't come on and you have to turn them on and off and then the light will fire.
If I was going to do it again I would go with a relay.
twhitechurch
I am using both relay and can bus and without the relay it was like 80% of the time it would not turn on
Tylus
South GA
Can you post a pic of the relay setup installed? I'd prefer to have a hidden install. The CanBus setup looks perfect for hiding wires. Not sure if that's as easily accomplished via the relay method
CDallasAtor
I would also like to see how that all works out with the can bus and the relay harness. Im having an intermittent issue with the drivers side as well
smittydog
updates/feedback?
so, it's been a few months now since you all have put in the HID's...how is everyone's morimoto kit? Any dislikes? lessons learned?
Would you do the kit over again? Would you do LED instead?
thanks,
Steve
joo3yy133
