383 Stoker
sbowen
Elizabeth, CO
Tuning?
So what did you do to "max" out the fuel?
---------- Post added at 03:16 PM ---------- Previous post was at 03:15 PM ----------
I probably should have used this to ask the question: What specifically did you do to max out the fuel system?
branndon_b
Lake Charles, LA
i'm thinking he's referring to the tune, changing the air/fuel tables and such. i'm sure he'll chime in again, just sit tight.
bowtiefreak
No Quarter
Near Philly
Yup, through the software. I had a few runs on a dyno while the guys tuned it. It really helped bring it too life
sbowen
Elizabeth, CO
Tune
Thanks guys. Did you use your oem t-body? I assume your crate engine came with a performance intake. Do you know which one?
TigerEyz3
Slow and Steady
TN
The HT383E crate engine allows you to reuse the factory intake manifold and fuel spider - literally, plug and play installation.
If you're wanting to step-up the performance, you could run a ram jet intake, but that will not only require tuning adjustments, but some possible fabrication/rerouting as well (I'm in the early investigation stages of this option - it has piqued my interest, not to mention I could run different size injectors).
sbowen
Elizabeth, CO
383 stroker
I decided on a stroker kit from Skip White performance. Had everything to do the job right, forged pistons, internally balanced crank, flexplate etc. and the price was right.
1Agerry
Supporting Vendor
Good luck! and post some pic's as you go with the project!
bowtiefreak
No Quarter
Near Philly
Please post dynos.
I'll dig them up tonight, here is a summary:
Before a custom tune, I had a hyper tech programmer so the before is with a hand held program:
Before:226.6HP 297.3ft lbs at the tires
After: 261.7HP 378.3ft lbs at the tires
Well worth the tune, the numbers don't lie. Factor in a roughly 24% drivetrain loss and you get a motor with about 350HP, close to 500ft lbs of torque. Again, not bad for a reliable motor.
kevpar
