So since my torque converter still hasn't delivered, I decided to just tackle what I thought was a simple transmission pan swap. I didnt want to start my engine teardown then the torque converter gets lost or something. No idea whats going on at Fedex keeps saying being delivered then an exception but I am home all day. I am going to have it dropped at a walgreens.
Anyway, so I go to swap the b&m pan on. Everything is going well. Got the old fluid out without making a mess.
I go to torque the pan on.
Problem #1. Missing one of the bolts.
Problem #2. The bolts they provide are way too long. They were bottoming out way before the washer hit the pan.
Problem #3. The stock bolts cannot be used! They are too wide.
Problem #4. My Yukon is my only vehicle while wife is at work.
Problem #5. My Kooks y pipe had no clearance.
So I hopped on my nice Trek bike and went to the hardware store. They didnt have any button head bolts, so I picked up 36 washers. I then tripled up the washers on the b&m bolts and just left one hole empty. Its not leaking so far but first thing tomorrow I will go get some new bolts and replace them.
The Kooks midpipe problem was a ***** because theyre slipfit and were the biggest PITA to separate. I spent an hour with a torch and peneteating oil and finally got them apart.
Then I went to get my exhaust expander and the oring that holds it together broke lol. So I could not expand the exhaust to make it easier. I ended up just cleaning it as best I can and applied grease to the connections then I just forced them back together. I was able to get the clearance I needed which was a relief. I was thinking maybe the pan was only designed for stock but luckily it clears.
Its a real nice piece I just wish they sent the correct hardware.
