- Joined
- Jan 3, 2011
- Posts
- 50,267
- Reaction score
- 16,824
If you're looking for them to issue a recall on this by recommending that everyone run in Auto 4wd all the time to make their SUV break it'll never happen. The vast majority of people only use anything to do with their 4wd (auto included) when the conditions suggest it as there's no reason otherwise. These vehicles have a VERY good traction control system which the majority of people find adequate enough for rainy conditions and is actually good enough with several inches of snow on the ground so 4wd is rarely even needed unless you have 8" or more of fresh snow or you're going through mud. These are the reasons why I find it ludicrous for anyone to run in Auto 4wd all the time and I'd bet that GM never counted on it either even with the service guy at the dealer stating that you should be able to. I'm betting that the reason the auto 4wd senses wheels spin while turning is because essentially one wheel IS spinning at a slightly higher rate than the other as the vehicle makes the corner. Depending on what the variables and setting are in the program this could engage 4wd (if running in auto 4wd all the time) on dry pavement and cause significant damage. No thanks. I'll continue driving worry free and not having my vehicle in the shop and only use my 4wd system when the conditions call for it
