Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
quick question before i put the tank back up. When taking it down, there were 2 fuel lines on the tank 1 left 1 right, nothing on the center. Is that the correct way or is there supposed to be a line there?
correct. but you know while you are at it if you think you will need to changes your leaf springs, take the mounting bolts at the spring bolt in back of left leaf pack, remove them and put them in the other direction. otherwise the tank will have to be moved again.
okay tank is back in place, new cap and rotor are on, need to get a diff hose clamp for the hose next to the filler hose. Then I will go for a drive....
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
