blanchard7684
Senior Member
- Joined
- Dec 23, 2024
- Posts
- 200
- Reaction score
- 86
Yes the difference in throttle position is precisely related to ve.Yeap, just like mentioned above, the 5.3 might need 30% throttle to achieve the same power the 6.2 does at 20% throttle.
So for all use cases that don't call for more than 355hp (the amount the 5.3 makes), the 5.3 will have the throttle open slight more than a 6.2 making the same power.
Once the 5.3 hits wide open throttle, its done, can't draw in any more air, so injecting more fuel wouldn't do anything to make more HP. Whereas the 6.2 can draw in more air thanks to its larger displacement, so it can inject and burn more fuel, making more hp.
The ve is not constant until wot.
This is why timing maps are dependent on rpm and load as well.
As the load increases, ve goes up because more air is entering the cylinder. To keep the power level the same more fuel is added but the ratio does not necessarily default to 14.7.
If you have been to any dyno or even seen one on media you’d know that the afr isn’t just either 14.7 or 12.8.
