Bad mpg?
Status
Not open for further replies.
Antonm
The facts are not in your favor here.
You keep claiming but you are wrong.
I’ve explained why.
Sorry this isn’t a return policy for range disabler.
You've explained nothing expect a bunch of incorrect useless gibberish for a clueless individual (that's you BTW).
And yes, Holley/ Sentinel Capital partners are pretty much crooks. They got my money, hope they don't get anyone elses.
Antonm
Yep that is right and you jumped into a discussion you don’t have the shoes for
Keep hitting up Wikipedia for your info
I'm an engineer, I jump into technical discussions for a living (usually the person I'm talking with has at least a basic understand of the subject mater at hand though, unlike in this case).
You should be taking notes here, you might (although you probably won't due to you aptitude) learn something.
Antonm
I stand by the statement and erased it on accident .
Ohh you caught me.
Refute that statement then if it is so stupid. Should be easy for a genius like you.
this statement,
this is the statement you stand behind and erased on accident ?
And you want to be taken seriously/ want people to think you have clue? And you don't think that this statement demonstrates a gross conceptual error?
Okay, awesome. And BTW, that statement was refuted the first time I quoted it (you know, before you erased it on accident) see post #43 on page #5 (like you really should be taking notes, we're going over the same stuff like three or four times)
blanchard7684
Senior Member
It would look like gibberish to uninformed people.
blanchard7684
Senior Member
Jesus..an engineer this ignorant is a menace to society.
blanchard7684
Senior Member
this statement,
Yes....so refute it.
blanchard7684
Senior Member
Really?
You don't think a 5.3 towing a trailer up a hill at 80% throttle (with an AFR of 14.7), will be making way more power than a 6.2 at driving on flat ground at 20% throttle (with that same 14.7 AFR)?
But maybe you meant to also include "at the same throttle position", and I'm just pointing out little things.
Is this what you want to go with?
Ok...
1) 5.3 towing uphill at 80% throttle WILL NOT BE AT 14.7 no matter how many times you try to type this out. The 5,3 will be deep into fuel enrichment (depending on gear) and close to max power so there is no feasible way you can claim it is at 14.7 afr.
Ergo of course it will make more power than a 6.2 that is on flat ground cruising.
2) 5.3 L cylinder mixed at 14.7 air/ratio will make less power than a 6.2L cylinder at 14.7 afr because the smaller cylinder will have less fuel in it.
From 1 and 2 you can see that at part loads (where a 6.2 can be at a higher afr) it will have incremental efficiency over 5.3. The 5.3 has a small enough displacement difference that it will need more fuel to make same power as 6.2.
If this isn't the case, then there is no need to have higher displacement engines.
If every engine on earth that runs on Otto cycle makes the same power at every AFR, or at 14.7, then it must be an illusion when dyno sheets show that a stock 6.2 makes way more power than a stock 5.3 at wot (13.1 afr).
In your view, no matter what the afr is, the 5.3 and 6.2 should make the same power in virtually all conditions of driving. This is ludicrous beyond what the english language can accurately describe.
Status
pyrocomics
