Ball Joints and Sway Bar links
Thank you for reporting back on the results of your project. Congratulations on completing it.
I had the same issue of a disconnected electrical connector when I changed out my rear shocks. My Tech 2 lead me directly to the source of the issue.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Great you got work done and handles great.
Be aware, the a/c system has a leak and now with a full charge the system has more pressure and will leak again, but how quick, I have no idea. The system is designed to not run low on refrigerant unless it has a leak. If that slow and was not empty, I suspect a shrader vale that leaks slow under the caps or another seal on a connection(s).
MarshMarlowe
MarshMarlowe
Yeah. They added some dye to the system and advised I bring it back if it stops blowing cool again
OR VietVet
Multnomah Falls
Military
Willamette Valley
That is good info. Might want to not wait that long for the check. Maybe drive a month and check. You can also look at any connections and at center front of a/c compressor for wet looking dirt. When it leaks, a/c oil comes out and will look wet and dirt under hood will cling there.
conrual777
