Ball Joints and Sway Bar links
St. Louis
Curious, why did you go with two different brands of tie rods?
The tie rod bellows are of varying qualities; the GM OE stuff the best and uses the proper clamps to keep the boot waterproof.
I don't think the GM inners come with new bellows, only new clamps
You said you replaced the rear shocks also. I think there's a wire harness/connector near where the upper shock bolt goes on the back side of the frame. This sometimes gets disconnected when removing that shock bolt.
There is, on top of the frame, almost right in line with the bolt head. If you even so much as think of removing that bolt, the connector comes unplugged.
*EDIT* I see this was covered a few posts later.
St. Louis
When I replaced my rear shocks a couple years ago I didn't have a problem with that connector coming unplugged.
The shock instructions did warn about it though, and many people on here have had the problem, so I went into the job aware of it and was just careful when messing with that top bolt. Using the correct combination of socket and extention might have helped also.
MarshMarlowe
MarshMarlowe
It's amazing that the connector doesn't just jiggle loose on its own
Show off. :p
I knew about it and still knocked it loose during my lowering job. Of course, I used an impact fed by a 3/8" hose from a 60-gallon compressor at 150 psi and immediately went WOT to vehemently release all of its ugga duggas on that bolt. Because wrench monkey.
MarshMarlowe
MarshMarlowe
Hey again everyone. I just got the Tahoe back from the shop
They did an alignment and an AC diagnosis. They found the AC held pressure, but it had just under a pound of freon, so they recharged it. All seems well now
I'm not sure how long the ball joints, tie rods, Sway Bar links, and shocks were bad, but the truck feels better than ever now. It used to handle like a covered wagon hauling a bathtub half full of water, but now it's so stable on the road.
Man what a difference
Thanks again for all your help!
cofferson
