Blazed's 2011 Tahoe Build
Status
Not open for further replies.
Modded
That Guy
The struts are ok unless you are hitting repetitive bumps then they don't respond fast enough.
---------- Post added at 03:28 PM ---------- Previous post was at 03:19 PM ----------
Could this work guys?
Yeah just pull your drive shaft, CV axles, and 4wd hubs. Then reinstall 2wd hubs.
Why do you need to though?
---------- Post added at 04:58 PM ---------- Previous post was at 04:51 PM ----------
Hmmmm. Wonder why that is. :think:
I wish I could have the stock struts "modded" like Tony says.
@ Blazed.......I would leave it be Bro.
A extensive modification, especially one that renders a sought after feature......useless, is not going to bode well come resale.
It has to do with the front being s strut assembly. Struts offer better response than a separate coils and shock assembly.
I do not like the danger of getting a lip machined in the front shock to hold the lower strut seat lower (which essentially drops the front of the car). Reason being that you just took away from the casing of the shock, which can cause it to break if it is put under trying conditions. That would not be a very fun accident if/when that happens.
The chances are slim that something crazy like that would happen, but it is more likely if that lip is machined on there.
Blazed
Blazed
Accepting Donations
Im saying a way that could be put back to stock for resale.
---------- Post added at 08:03 PM ---------- Previous post was at 08:02 PM ----------
Thats what I figured I could do most of that myself.
But how much would the hubs be?
---------- Post added at 08:05 PM ---------- Previous post was at 08:03 PM ----------
According to some part numebers I found I wouldnt have to replace hubs....
excuse my newbness but what is the hub and what does it do...?
if you describe it i will probably know because ive changed out my spindles twice now.
Goodinblack
I Like Tacos
Dirty South
The hub is the "big thing" that goes into the "big hole" in the spindle.
Lug nuts and all.
---------- Post added at 07:27 PM ---------- Previous post was at 07:26 PM ----------
I NEVER thought about that. :shakehead: Thanks for pointing it out.
Modded
That Guy
The hub mounts to the spindles with three bolts.
In 2wd models, it spins freely. In 4wd models, the CV shat turns them.
And yes, you absolutely need them.
Should run no more than $180 for both.
Blazed
Blazed
Accepting Donations
Lug nuts and all.
Oh ok.
Well according to this parts website they are all the same...
So it looks like I'd just take the axles out and the drive shaft and call it done. Of course I'd cap it off.
---------- Post added at 08:45 PM ---------- Previous post was at 08:43 PM ----------
My last post was before I saw yours modded.
That makes perfect sense I wonder what's up with that website I was looking at thenzzz
So if I took the cv axles out the hub would be locked in place and not spin?
Or if it does spin it wouldn't be without effort?
Regency
No the reason I want to de-4x4 it is because in order to gets 3.73s which is what I want I have to get a bigger carrier but on a lowered Tahoe I don't even need 4x4 so if its not to expensive I just want to get rid of it.
I know I'm saying save up to get front and rear done so you don't have to de-4x4 your truck
Modded
That Guy
The 4wd and 2wd hubs are similar (both can spin freely), but the 4wd hub has a hole in the back for the axle to go through and bolt down on the other side. They are not the same though.
You could just pull the front driveshaft if you want now that I am rethinking it.
Do you not have an option to put the Tahoe in 2wd?
Also, why do you want it 2wd? If you are using only 2" drop spindles your 4wd feature will still work?
Blazed
Blazed
Accepting Donations
I thought soo....
And I can put it in 2wd I want it to be 2wd only so I can get 3.73s
I can't get 3.73s in the front because they don't fit and besides even if I could its more money.
---------- Post added at 09:24 PM ---------- Previous post was at 09:23 PM ----------
Modded out of curiosity where did you learn so much about cars?
Modded
That Guy
I thought soo....
I have always been around cars and always liked watching my dad and mechanics work on them. I am not as good with cars when it comes to the mechanical modification basis, especially performance parts. But almost everything else (like suspension and electrical), I am good at, or learn real quick. Also, when I am bored on the internet, I read up on car stuff to learn more.
With your whole 2wd issue I was a bit confused and had to think it over in my head a few times haha.
Blazed
Blazed
Accepting Donations
So I'm right tho right?
I can just take out those three parts out and be good?
Status
witty_name
