Blazed's 2011 Tahoe Build
Status
Not open for further replies.
Regency
You have to take the motor out of the transfer case it's pointless though just save up for 4.10 gears for your 4x4
Blazed
Blazed
Accepting Donations
No the reason I want to de-4x4 it is because in order to gets 3.73s which is what I want I have to get a bigger carrier but on a lowered Tahoe I don't even need 4x4 so if its not to expensive I just want to get rid of it.
Goodinblack
I Like Tacos
Dirty South
Even if you can, don't do it.
You will end up selling one day, and regret it.
So Modded, what shocks are you running in the front now? I missed this...... Without reading through it all.............
Blazed
Blazed
Accepting Donations
What if I just took off the drive axel for the front diff? I could put it back on.
And he's running bell tech sp shocks in front to get the 3rd inch down
jdpber
GOLD MEMBER
The America
You could do that. But I think it will throw an error code on the front diff.
Administrator
You'd be MUCH better off just selling your Hoe for a 2WD Hoe rather than "de-4x4"ing what you have.
Blazed
Blazed
Accepting Donations
Make it easier to work on the front end and cheaper and easy to get 3.73s
---------- Post added at 12:25 PM ---------- Previous post was at 12:22 PM ----------
I don't have that option.
Administrator
In the end it'd be cheaper but turning your Hoe into a 2WD will cost a pretty penny I'm going to guess. It's not as simple as just taking the front diff out and magically you have a 2WD.
Then say that you do decide to turn it into a true 2WD. Do you plan on modding your interior to remove the 4WD selection knob? Obviously, not real hard I'd imagine but it'd be silly to keep that knob and not have any function anymore.
Either way, I'm along for the ride to see what you do :popcorn: There's got to be a ton of white 2WD Hoes running around that you could acquire, move your mods over to and then sell your current Hoe and you'd end up ahead or worst case scenario break even.
jdpber
GOLD MEMBER
The America
Buying diff car and swapping sounds like a much easier outcome. Also why did you buy a 4wd and drop it to begin with. Why not get a 2wd from the get go.
Status
dropit
