Don’t forget to flush your brake system - 3yrs or 45k
SuperOldSchool
Hello all
I’m **** about routine maintenance with all my cars. Just flushed the brake fluid from all 4 calipers this morning.
The pedal feels more firm and I was surprised. Normally I can’t tell, so there’s proof it was a good time to do it.
51k on my 2015 Yukon. Manual states to do this service at 45k or 3 years, whichever comes first.
Brake fluid is typically clear, unless you’re using specialty stuff like ATE Blue.... here is what came out, glad I did it.
892CCBAA-98CC-40F1-AEC3-24A54AC4DD46.jpeg 12D9EF64-E365-4098-848D-D14193240BF0.jpeg
SuperOldSchool
SuperOldSchool
...forgot to mention, don’t forget to grease the 2 zerk fittings to the left of the hub - fronts only.
I believe these are the only 2 serviceable lube points on the suspension...
Nickfire20
Sounds good, looks nasty
Thank you!
cardude2000
Hello all
View attachment 194502 View attachment 194503
Dumb question. What does it get dirty? It’s a closed system isn’t it?
SuperOldSchool
SuperOldSchool
The fluid breaks down from heat. Brakes get Hot!
Plus, I think air does deep from the reservior cap- minute amount over time.
SuperOldSchool
SuperOldSchool
How do you go about flushing the brakes, anyway?
There are tons of descriptions online. Basically suck old fluid out of reservoir.
Refill with new.
Bleed brakes starting with caliper farthest from reservoir- bleed until fluid runs clean.
Several ways to bleed - helper pumping pedal,vacuum bleeder, pressure bleeder.
Search - how to flush brake system or bleeding brakes procedure...
ezstriper
brake fluid absorbs moisture, that is its big killer, the more moisture the less pressure the system has...
kentman
Wilmington, NC
I do the fluid every two years. I have new speed bleeders that I am going to install next month and do the fluid. I am hoping that the Yukon XL brake lines are better than the Pontiac lines were. I had two Pontiacs previously, and both had major rust-through issues in the lines about ten years out on each.
kyle09
