Growing up doesn't have to suck
89Suburban
Bull in the china shop
SE PA
Since I finally got the all hose clamps I needed from the salvage yard, I was able to install the heater hose connectors. I definitely wanted this to be done before the engine was back in.
3/4" heater core connectors and 1/2" rear heater core connectors. The hoses to the two nipples on the water pump are 5/8":
About 12" each of 3/4" and 1/2" heater hoses and box of 3-way Ts and factory hose clamps (factory from GM, Ford and Honda :D)
Semi-comfy seat on cross member in engine bay:
The 1/2" tubes were too close, so I trimmed them down:
Minimal, but adequate gap and perfect alignment:
Chis are those tee's pressed together parts or 100% machined one piece?
89Suburban
SE PA
The 1/2" nipple is pressed in. It may be epoxied, too.
So you feel confident with it I see, I am probably going this route just wanted to make sure. :) I have to search for spring clamps though. Not sure if I can get them in a minimum qty in the sizes needed.
PAW PAW missing you
^^^^This. :hands:
PAW PAW missing you
^^^^This. :hands:
:console:
Awww. Sorry, pops. Yesterday was busy and long and I missed a lot of new posts on the forum. Wasn't feeling well when I got home. Pretty sure I have the 'rona. Trying (again) to go get tested. The good news is I'll be off work for a few days so I'll be around more for a little while!
^^^^This. :hands:
I didn't see any reason to doubt them and, so far, they've survived 5,000 miles with lots of 6,000 RPM action. I used a mixture of clamps from Ford, GM and Honda, IIRC. The Honda clamps seemed to have a tighter fit for a given size.
raejay
