- Joined
- Aug 2, 2018
- Posts
- 8,098
- Reaction score
- 11,219
Thank you for your quick replies and recommendations, folks. Very much appreciated.
I would just use some tin snips to cut those old parts off, but glad you got them off. Just make sure to get genuine ACDelco T’s and NOT the Dorman ones, but that Dorman Heater hose with the metal Y is better that the OEM one.I got both heater hoses off the plastic 'T's, but what a PIA to to it! There is virtually no clearance to work in there, with those plastic 'T's sending coolant to the rear heater in the way of everything. The connector removal tool did not work, as the support structure of the plastic 'T's did not allow the tool to fully close around the nipple to disengage the white plastic tab hooks.
So, with a hack saw blade, I was able to cut the connector bridge pieces at the bottom of each window on both sides of the connector outer housing, and this allowed me to pull the connector outer housing off the nipple. Then, with curved needle nose pliers, I was able to bend the plastic hooks on the white plastic tab assembly out of the way of the ridge on the nipple, and slide the plastic tab assembly off the nipple.
Now, to get replacement hoses and reinstall.
Yeah they’re quick connect but not quick disconnect. Easy. As hell to install.The replacements will just push-n-click on.
Now you know why the factory used quick connectors on those.
