Help blower motor
jamison2021
I just picked up a 2005 Tahoe from my parents this weekend. The blower motor only worked on fan speed 5 prior but this morning it had stopped. I went ahead and replace the resistor as well as the harness going into and now it’s working speeds 1-4 but it’s shutting off for 5. I don’t necessarily need it but I would just like to know what the community would say
Thanks!
Welcome to the Forum from NH.
Pics of the truck, please.
@swathdiver may be able to provide some guidance on what to check next.
So this is a manual HVAC control, right? Not the digital where a degree value can be set.
There's one fuse for the HVAC in the underhood electrical center (fusebox) -- and another if you have rear heat -- and two more in the driver's side instrument panel fusebox (accessed by opening the driver's door and opening the fuse panel cover). Are those fuses good, and do they have voltage on the circuits?
Multnomah Falls
Welcome to the forum from Oregon.
Being a 2005 Tahoe owner, I will say that the blower motor and resistor should be replaced in pairs with quality Genuine GM parts. Like @Fless said, do you have the digital controller or the blue/red panel on the front? I am getting ready to replace the red/blue panel controlled blower and resistor on a friends 2005 Tahoe.
Resistor #22807123
Blower #15-81646
By the way, the blower is a cinch to replace.
J
jamison2021
Resistor #22807123
Blower #15-81646
Thank you! I’ll check the fuses either tonight or tomorrow
TJ Baker
Colorado
toxic Tahoe 4x4
