Jonas's 79' CJ7 Build.....
Yuko04
Yuko04
"SquareBODluvr"
MN
Day 14...... Rearend pains!
-12 outside so I guess i better do something today......
Started out with this mess, but i Do have ALL my parts sitting in the shop. I have been an ordering,researching mofo...
Got everything broke down and figured out. I started by doing a mock up on the rear end to get my pinion angle to be able to have a SICK lift with NO binding issues.
So as you can see I will have some serious degree of pitch on the rear axle. 35" tires, and SOA lift. I am gonna set my pinion at 25 degree of pitch. You want your yoke to be about 1 degree over your transfer case yoke. Thats to accomidate for torque specs if she gets on er'. I will not over explain how i figured all this out...
Heavy duty perch pads so I wont have an "spring wrap" with everthing over axle instead of under.
For all my fellow fabricators out there......... Nothing but nickels!
Cutting stock perches off.....
Everything mounted up good. I got shock tabs to do and rear disc conversion and rear dana 44 will be done until I have gears and back lash set.......
Man that pinion angle is nasty!!!:licklips:
Administrator
Looking sooooo nice!! :rocking:
On another note....I see the 'Noma is still in your possession
Yuko04
Yuko04
"SquareBODluvr"
MN
Thanks Cob!
And yes. . About 1 call a week. No one has the loot. Im figuring once everyone has there tax check, she should be bye bye.
Jiggy-J
---------- Post added at 09:56 PM ---------- Previous post was at 09:54 PM ----------
Good lookin welds Jonas..
Thank you sir[emoji106]
Jiggy-J
Administrator
If you need someone to keep it exercised just let me know. I'd be glad to dd it for you :D
Yuko04
Yuko04
"SquareBODluvr"
MN
Well, we'd have to wait for the snow to melt. With the one wheel wonder, i can barely get it out the driveway.
Lol!
Jiggy-J
Yuko04
Yuko04
"SquareBODluvr"
MN
^^^Thank ya sir! True "meow" inspiration!
Jiggy-J
jdpber
GOLD MEMBER
The America
That one weld looks crooked....best start over [emoji12]
AustinC
