Kicker zx300.1 Amp
blueflamed03
Oklahoma
copying a good section of info over, as there is a ton of info to be had.
Class A designs have current constantly flowing through the output transistors even if there is no incoming audio signal, so the output transistors are always on. This type of amplifier has the lowest distortion of any but it’s extremely wasteful and inefficient, dissipating 80% of its power in heat with an efficiency of only 20%.
Class B amplifiers use output transistors that switch on and off, with one device amplifying the positive portion of the waveform, the other device the negative part. If there is no incoming audio signal, then no current flows through the output transistors. Consequently, Class B amplifiers are much more efficient (about 50% to 70%) than Class A designs, however there may be non-linear distortions that occur when one set of transistors switch off and the other set switches on.
Class A/B amplifiers combine the virtues of Class A and Class B designs by having one output device stay on a bit longer, while the other device takes over amplifying the other half of the audio waveform. In other words, there is a small current on at all times in the crossover portion of each output device, which eliminates the potential switching distortion of a pure Class B design. Efficiency of a Class A/B amp is still about 50%.
Class D amplifiers, although there are a number of different design variations, are essentially switching amplifiers or Pulse Width Modulator (PWM) designs. The incoming analog audio signal is used to modulate a very high frequency PWM carrier that works the output stage either fully on or off. This ultra-high frequency carrier must be removed from the audio output with a reconstruction filter so that no ultra-high frequency switching components remain to corrupt the audio signals. As previously mentioned, Class D designs are extremely efficient, typically in the range of 85% to 90% or more.
so in street terms, A/B is great clean amp for front stage, and small sub setups like this 300.1 (350watts) and classD amp are great for larger, more powerful sub setups.
Upperorbital
