LED Light Bar mounted in Z71 Rack?
osidesurfer365
San Diego
The only downside I see is the light output will not be as strong since the roof is reflecting a lot of the beam. Better projection if there are no obstacles
osiris94ej
Casper Wyoming
I've thought about this but facing the rear, with a slight tint. Just for those tailgaters/impatient ass holes in traffic. Also auxiliary reverse when light is needed.
Sent from my SM-N920V using Tapatalk
Crcz71
Anderson SC
Done it. Been done about a year. Lights up great. I actually have mine mounted between the front caps. 42in bar used brackets for a 52in curved bar.
Crcz71
Anderson SC
I order the brackets for a 52 like I said. But I had to open them up some to fit correctly. I welded three nuts on some 1/8 flat stock about an inch wide put them on the inside of the caps and used stainless bolts.
YukonXL04
The Riverboat
Arlington, TX
That's actually a really good way to cut down on the extreme foreground lighting that actually hurts your distance view because it's so bright.
Crcz71 - does it interfere with your sunroof at all?
Jcurt
