lifespan of leaf springs
95escahoe
Good evening, I have a 95 Tahoe has around 237k and change on it has new struts and shocks and rides fine, was wondering how long leaf springs are good for since I have alotta miles on the truck they look to be in good shape no sagging or anything, thanks for the help
TigerEyz3
Slow and Steady
TN
Hard to say... all depends on cycles and loads (not mileage or years). Ride 'em until you encounter a problem (sag, typically uneven from one side compared to the other), then replace the entire set.
AtomicHoe094
Atomichoe094
cleveland, OH
strutss??? lol coils and shocks up front, shocks and leafs in the rear.. I looked into replacing my leafs, but way to expensive for me, so ill just replace the bushings and such later on..
95escahoe
95escahoe
lol ya thats what I meant
---------- Post added at 02:16 PM ---------- Previous post was at 02:15 PM ----------
As Long as they are not rusted out and not sagging you should be fine until they do.
ya there fine no sagging, who knows maybe they were replaced at some point, but thanks for the info
retorq
Kingman AZ
They probably won't sag much just sitting there, hook up a trailer and see how it sits. :D
Administrator
The springs on my 77 are original and still holding up perfectly fine so I'd say they have potential to have a very long life span and should last a very long time unless doing consistent heavy towing or hauling ;)
Jaycenk
Florida
The springs in the Hoe's and Yukons all seemed to drop a bit more even brand new from the factory than expected under load, didn't they?
AtomicHoe094
Atomichoe094
cleveland, OH
That is, if your not banging FAT chicks in the back of the truck all the time, then your springs should be fine
:evillol: hahahah
gy_psi
