My From Start to Finish 6.0L Build
MrMonte
Yep, I have a word document I created and I follow. I too use zip lock bags and mark accordingly. I place the parts in the back of my Tahoe. During the install I just follow the removal in reverse order. I even have torque values listed out for the install. I'm a bit **** that way - plus at my age I need the assist.
+1 on the zip lock bags. I label then store in order of removal then install in reverse order. Some bags may only have 2 bolts in them. Makes reinstall so much easier.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
I always try to take pictures before disassembly. I used to think I'd remember where something went--but I usually forgot lol.
When I started in the shops, an engine swap was way easier. Way less to remember as you reinstalled anything. That was before cells that took pics. I saw how the cell pic could make the remember task way easier.
RAMurphy
RAMurphy
Bob
Military
S. Maryland
You are so right, I pulled engine from a very early Toyota Corolla - very simple, hardly any wiring harnesses,
RAMurphy
RAMurphy
Bob
Military
S. Maryland
So Sunday was a day of rest and Monday was spent counting money for our church in the morning. So between Monday and today I was able to get closer to removing the engine. This is what I accomplished:
  • Disconnected main Vacuum line from brake booster.
  • Removed Catch Can
  • Disconnected fuel lines.
  • Remove Fuel Inection Wiring Conections from Fuel Rail/Injectors.
  • Removed fuel injector assembly.
  • Removed EGR thing from front of intake manifold.
  • Removed PCV valve hose from driver’s side valve cover.
  • Removed intake manifold.
  • Removed belt tensioner assembly.
  • Removed lower radiator hose from water pump.
  • Removed two interior heater hoses from water pump.
  • Removed water pump (6 Bolts).
  • Removed alternator.
  • Removed four bolts holding power steering pump (3 in front and one behind (bolt in gallon bag)
  • Removed four bolts from alternator support bracket.
  • Removed alternator support
  • Removed two 10 mm bolts from the red box power junction support bracket.
  • Remove dipstick and support
Removing the Power Steering pully was a PITA, The SOB would not budge. Used heat and *********. I ended up pulling a pec muscle - getting old.
strutaeng
Dallas, Texas
  • Removed Catch Can
You don't have a longer ratchet?
A few months ago I bought a 1/2 Gearwrench locking flex head ratchet and that thing is a friggin beast. I was used to using a 24" breaker bar, but ratchet is much more versatile.
Air impact and/cordless impact are also nice to have handy and used as needed.
Very nice write up BTW.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Another great source for durable tools at a great price is the ICON brand.
RAMurphy
RAMurphy
Bob
Military
S. Maryland
Thank you, Yep, I used different rachet and a breaker bar with a pipe extender. It finally broke free - after I pulled my muscle.
strutaeng
Dallas, Texas
I've looked the ICON brand at HF but haven't bought any. They do look like quality tools though.
For this flex head ratchet, I wanted the one with the detents. I have the HF 1/4" flex head ratchet it bugs me that often the head moves on you while you are trying to reach a bolt. In addition, the Gearwrench also locks. It slows you down a bit to unlock, adjust the head angle, and relock. But I don't mind that at all.
It's this one if anyone is interested:
I hope you get better soon.
I'm much enjoying your build BTW. :)
Cashbagz1
