makintoshnex
- Joined
- Sep 30, 2023
- Posts
- 154
- Reaction score
- 76
Truck running with 14.2 volts. That's still missing I will do that 7 cylinder tomorrow. It's really dark and cold+ rainand it's still missing? ugh.
it looks like you got it nice and clean.
does it still sound the same as in that video?
Interesting. Now I have fuel pump![]()
Ok, I will take a look. I'm waiting for my delivery from Amazon, I ordered some brake switches and it's control module. I have a guess. That's might be the abs module itself. It's all corrosion on module. Maybe there is bad connection.there's another guy currently dealing with a randomly stalling out problem, not the same as you have. but it lead him to the fuse box. I guess you can pop the fuse box like in half top to bottom, and check for corrosion inside. he found it wasn't fully seated. with all the weird codes you are getting, and low voltage I thought of yours while reading thru.
Post in thread 'Is there any certified GM techs in the group? U0109 is driving me insane.' https://www.tahoeyukonforum.com/thr...0109-is-driving-me-insane.144686/post-1840522
just a thought. I've never had one apart thou.
I mean I can't drive faster, just because it is not safe. I bought some parts. Let's see what I can do. Maybe some switches are bad.it won't let you drive faster than 20mph? I've not had mine give me issues, I didn't expect that. I thought it just disabled it. if you need to drive you can try holding the button for 5 or 10 seconds to turn it all off. it's the one down below the radio with the little car on it.
you might check, I believe that abs module, if it's the one I'm thinking of needs to be programed to the truck. your scanner might do it. I don't know anything about the one you have but it seems to show stuff byond just the engine ecm, so it's probably better than normal cheap ones. if doesn't the dealer can do it. worth a search thou.
