David Smith
Aside from waiting until I have the old one off lol. Show online that it ''Fits My Vehicle"
The pickup tube for the transmission is press fit, no nut/bolt. The bracket on the tube that secures it via a bell housing bolt is 37 ft lbs like the others.
He is looking for torque specs on the oil pump pick up tube. The bolt that secures it to the oil pump and the bolt that secures the bracket on the tube to the block.
How can I tell?
Absolutely. The only other thing that I did at the same time was change the oil and oil filter. The old o-ring was kind of flat, so I am positive that was the issue.^^^
That's great to hear, so can you say for certain that it was the O-ring?
Previously I had changed the oil pressure sensor, which did nothing.
