Paint touch ups and rust repair
tungsten
tungsten
What are these thread clips called? They go into the square hole around the fender and rear fascia.
tungsten
tungsten
Bondo sanding. Made a curved sanding block to match the body. Makes it a little easier.
tungsten
tungsten
Sanding bondo. Not much fun. Getting ready to spray some primer too see where I am.E9E9B227-F9B8-43AD-BDE3-7C28302F52D8.jpegworking also on sanding headlights. They were really foggy.Quite yellow. A lot of wet sanding later and not too bad.F8F4D94E-4F91-4046-90DE-504FD1A6335B.jpeg
tungsten
tungsten
Bit of whoops on my first blend attempt. Tried wet sanding down the tape line and now have a blurry patch. 0FCFEECA-471D-4E14-B4D4-2E3D946BBCDA.jpeg1E3CDAEA-96DE-4DF1-911F-47E19177199D.jpegColour doesn’t match anyway so will clean off the wax sand it all with 1500 and see if I can match a little better. I think I’ll add more clear also.I’ll tape some raised curved masking also to try and blend the clear in.
Is there a special clear for headlights?
Not really sure. Maybe you can inquire at a place that sells body shop supplies? When I used to do them for my business I'd use a 2 part clear that I'd apply with a limitless towel. It had a uv blocker in it. Unfortunately I used to buy it from the trade school I went to, and they rebottled with their own name on it.
tungsten
tungsten
Ill do some research thx,spraying my 1k clear on maybe an option.
ford_siesta
