Project---------------Tahoe
Administrator
This is going to be cool build!! The T56 swap really intrigues me :)
M Hankel
M Hankel
Vancouver, WA
Thanks all. Should be a fun driver when it all comes together. The entire drivetrain from front pulleys to rearend will be completely new or rebuilt.
I will be hand porting some 317 heads and milling them to get the compression back down. The cam is a custom grind, 228/230 .587/.592 on a 112 LSA. I'm shooting for 420rwhp as a personal goal but I'll be pretty happy with anything over 400rwhp. Sounds big for a "truck", but it should work really well with the T56 and 5.13 gears (31.5" tires). Didn't want anything with crazy valve lift because I want the valve springs to last more than 25k miles.
Still need to order up front/rear seals for the engine covers and few misc gaskets to get the bottom end buttoned up. Haven't decided on a oil pump yet. Ported LS6 or a Melling unit.... ?
I'm leaving on vacation the first week of July. Was hoping to have the T56 and gears installed before I left but the damn T56 mainshaft is still on back order through Tremec and I haven't received the repaired one back yet. Once I get back from vacation I can at least get the rear gears installed and continue to port the heads. Hopefully the mainshaft will show up before July 10th. :)
Mike
M Hankel
M Hankel
Vancouver, WA
Thanks. I'll be making some progress within the next couple weeks. Just waiting on parts to finish up the short block. Here's a list of order for things yet to get done.
-Degree Cam, this week
-Install new seals/gaskets on short block once parts arrive, hopefully this week
-Flow test stock cylinder head, this week
-Disassemble C5 Corvette T56 Trans, this week
-Rebuild T56 to GTO style, this coming weekend
-Start cylinder head port work and re-flow test one chamber, next week
-Hoping to install the rear end gears the weekend of the 26th of this month.
Mike
M Hankel
M Hankel
Vancouver, WA
Updates,,,,
So, it's been a pretty crappy couple weeks. Everything,,,, and I do mean EVERYTHING has been fighting me trying to get things done. Wrong parts show up, parts not working as they should, broken tools etc... But, I did get the gears installed finally after three days of cursing lol....
So,,, I spent a good amount of time setting up the gears to get a good wear pattern. Then I go to install the axles and need to remove the cross pin from the carrier assembly. Then I find this!!!! The damn pin can't come out because it hits the teeth of the gear!! WTF??
So the next day I called Rons Machine Service where I bought the gears and Yukon Duragrip package. He said "oh that is common with the 5.13 and 4.88 gears. Just grind the corner of the gear tooth away and it should clear no problem, just stay out of the wear pattern. We even have a 'how to' vid on our website". Dandy.... There goes 4 hours setting up my wear pattern I just accomplished. Well, I started thinking about it and I had to pull the ring gear off to get the pin out anyway. So, while it was out I just milled the pin flat on one side to clear the gear. I was a little nervous wondering if this would work or not. But, all is back together and it works just fine. Gears are pretty quiet. I thought they'd be a bit noisy since a numerically higher gear is usually louder, but these will work out just great. :)
Here's a couple pics of the milled down pin.
As for the other updates... well lets just say I'm still working on those and leave it at that. I hope things start going smoother or this is going to be a five year project!!
Mike
BlueTahoe2001
Charlotte, NC
Can't wait to see this project finished and see how it runs. How do you think the T56 swap will be? It seems it could possibly be fairly difficult considering all the electronics you will have to deal with.
M Hankel
M Hankel
Vancouver, WA
I'm not too worried about theT56 swap. I was dreading the gear swap more so than the trans. My buddy just yanked a motor from his 03 Silvy and said it want too fun. Kinda not looking forward to that now either lol...
Mike
M Hankel
M Hankel
Vancouver, WA
Finally got some free time to dig into the T56 rebuild and some forward progress made again. This transmission started life in a C5 Corvette and I converted it to a hybrid. It's basically got the newer/better syncros design from the Corvette/GTO with the Fbody case and a GTO main shaft.
Parts all cleaned and ready for final assembly.
Checking the bearing end play for the main shaft.
Checking the counter shaft bearing end play.
Checking the counter shaft extension bearing end play.
That's about as far as I got with it last night.
Mike
M Hankel
M Hankel
Vancouver, WA
Well it's been awhile since I've updated. I had some issues with the main shaft on the T56 and had to send it out for repair. Normally I'd just buy a new main shaft, but everyone in the country is out of stock on GTO main shafts, and Tremec parts in general. It took longer than expected to get it back, then when it did come back I assembled the trans again, only to find out the repair wasn't quite within tolerance. So, had to disassemble the trans once more and chock it up on the lathe to remove about .0015" where the 5/6 gear rides. Total pain in the ass but at least it's all together finally (third times a charm). Still need to install the top plate but it was getting late last night and I couldn't locate a GTO/Fbody top plate from my stock piled T56 parts. Guess I'll have to fabricate one from a piece of carbon fiber I have laying around.
I've also been hand porting some 317 cylinder heads while the trans main shaft was out for repair. I'll post up some pics of that once I get a little further along with the port work.
Mike
WashFarm
