randeez
no maf, no misfires. guess i need to learn how to tune idle without it
kinda tried some of your advice @iamdub
with the maf on, i tried to add some more timing (thinking if too much fuel was blowing out spark, more advance may have a chance of lighting off). tried leaning it out a little bit, was set "safe" with the PE around 1.3 (about 11.3 afr) on e85 i should be still be safe up to about 12afr. still broke up, up top, the MAF would just max out and bounce around between like 12,500hz and 13,500hz and cause all sorts of weird fueling. i'll post a screen shot of it breaking up with the misfire counts.
i did mess with the idle the other day and after failing out the MAF it is atleast able to start and idle, coast down is fine. turning on the ac and crap like that messed it up, wants to oscillate, and go down to like 500rpm n crap so it def needs work. little iffy coming up to a turn or something acts like it wants to stall out lol, gotta keep playing with it.
also 2>3 shift is kinda fucky, throttle closing...im promise im not letting off
i dont think i can command the shift to happen any faster so im not sure if the throttle blade is getting pushed closed or some sort of torque management is still in the tune somewhere maybe, i dunno. 1>2 does it seamless, 3>4 i try not to WOT that shift - mostly because that is like 140+ at that point but it seems to shift fast enough not to move the throttle blade.
need to back off the timing a little bit, thats like 17psi and 15* of spark, a little hot
uhh both of these were completed on a closed course
MAF on wot:
Speed Density wot
MAF on wot:
Speed Density wot
