went ahead and ordered two fittings for the back of the manifold, couldnt think of anything else i needed. one is o-ring right to the hose fitting, but says it doesnt swivel - not sure if description was wrong but it also doesnt look like it. so no idea which way the fitting is going to face when its tight.
also grabbed just a male>female 90 that can point whichever way, it may work better cause i almost want to like 45* away from the manifold anyway. using the oring hose fitting i need to make the bend with hose, and the large hose needs a good bit of radius to avoid flattening it.
also ordered a super tight radius 3.5" 120* bend aluminum pipe to probably make the charge pipe out of - not a fan of the pie cuts, hoping to make it all out of a single piece. tight bend probably isnt the best for air flow, but the alternative it basically to turn them both down and make a U-shape to come back up. part of wanting to do this is to improve out of boost response - as it is i've got this 427 trying to suck air through 6foot of 3" and 3.5" pipe and an intercooler when out of boost
![vpe-12191_xl.jpg vpe-12191_xl.jpg](https://www.tahoeyukonforum.com/data/attachments/332/332881-f819def0418338cd9e499e90df6eddd3.jpg)
