Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
got the controller for the bmw water pump, i also ordered a universal pwm signal generator from amazon and bench tested it off battery charger. but it pulls some amps wide open, like 36amps :eek:
i am kind of annoyed with the whole thing.... i did all this and its no faster so i want to redo a lot more lol :banghead:
i mean its together, it works, drove it around the past few days...not sure reliable is the word because i still check on things every time i drive it but it hasnt left me stranded.
guess i dont know the meaning of being done with it
randeez
randeez
south florida
As much as you’ve done to it you’ll probably always have to keep tabs on things on a regular basis. The moment you sleep on it it’ll piss on the ground or something lol
So...if I'm hearing you correctly, let's redo abunch of stuff?
pwtr02ss
Tennessee
dude, you’ve got a serious piece there. It’s awesome you can drive it to work, keep ac, and still trap nearly 140mph, in a full-size, fully loaded SUV. If you wanna go faster, I’m all for it. Love it right now. You’re a dedicated ****** and I like it
Sam Harris
Texas
This! **** yeah Randy. Killin it!
randeez
randeez
south florida
i know i know... maybe ill save big changes till i need to pull the engine or trans for a refresh or whatever.
plenty to do in the mean time, ill see if the tires cut any time off the 60'. may swap this waterpump out to keep the intake temps down. need to come up with a new lower mount for the limiting straps.
not sure about the future turbo/s build.... the size of big single turbo id need to make improvements is $4k+, but its worthless without more fuel and ecu to use it all. a pair of 76mm turbos can grab for 1500-2k$. either one i need to redo hot side so thats a wash
Legends61
