Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
leaks.
turbo drain oring shriveled up, couldnt find another oring so i threw a paper gasket on it, not sure if its sealed up - will prob get a new fitting. everything is 12an, bung on my oil pan is 10an. dunno ill see how the paper gasket does.
front cover from when i replaced the seal is leaking in the corner, cleaned it up best i could at the time. didnt feel like ******* with it right now so i cleaned the outside of it real good and squirted some black rtv along the corner where the block, pan, and cover meet.
fn tru cool is leaking also already. not at the fittings and i need to pull the front bumper off to see if i can find where from. is there even a warranty on these junk things? cant find anything on the website
leaks.
F'ing leaks:mad:!!
leaks.
According to Amazon the Tru Cools have a lifetime warranty.
I forgot the speed but according to that sheet it’s 135 or faster. Randy just ran 134.x so hmmm.
ya the closest track to me in Sacramento requires anyone that uses the track even for test n tune to have the associated license with the speed of the run I would imagine most tracks are similar.
randeez
randeez
south florida
my track is a little "loose" on the rules, for me anyway...been going out for few years now. main thing they look for is helmet under 13.99/100mph and jacket under 12.99 i think. website talks about diaper under 11.99 etc.... they would prob just tell me to run it in NT (no time) so its not shown on the board
the valve covers i have apparently dont use an oem gasket, they use just a round oring style hoping i found and ordered the correct ones. in the mean time i threw the stock valve cover back on - i thought the valves hit the stock baffling when i swapped them but i prob wont drive it very much till i can put the other covers back on
WindyCityDenali
