You could take some fine grit sandpaper and smooth out that spot on the oil pan.
See? Should have pulled that damn differential, eh?I hate it when you count 14 bolts, set them aside in a box under the truck, install them, then find out you're one short. I spent an hour, while the RTV was doing its initial cure hunting for this bolt. I looked everywhere, including around all the steering and differential stuff. I finally installed an old exhaust bolt which fit.
I began the final torquing of the bolts. When I got to the last "exhaust" bolt, I saw a silvery bolt hanging on my differential.-eh
I'll check the torque once again tomorrow and get things put back together tomorrow.
I used a gasket scraper tool ( you can get one at an auto Pratt’s store or Amazon) and Scotchbrite. You don’t need to worry about stuff falling into the pan since you’ll have it off and will clean it out anyway. The RTV just goes on the engine block side at the places in the diagram I posted earlier. I would figure on 4 hours so probably most of a day working at an “at home gonna take a few breaks” pace. Harbor a Freight sells this scraper kit for about $5.Well, with the whole Coronavirus shelter at home going on, looking at doing the oil pan gasket myself as the car won't be needed anytime soon. Reading through this thread has been really helpful but I did have a couple questions. When folks have done the oil pan, what did you use to clean up the surface where the new gasket will sit? I've seen some videos where people use a rubber, kind of nobby looking "scratch pad" type thing because it won't break down and gives you less of a chance of some residue breaking off the cleaning tool and ending up in your pan. Is there a specific tool at Oreilly or something I should look for. The other question was on the adhesive you apply to the corners, would you apply it to both sides of the gasket? I may be overthinking this but I'm basically a do my brakes and change my oil level of mechanic. Any idea on how long this type of job should take me? I'll probably just assume double what you all tell me
It's a 2007 Suburban so if there's any other gremlins I should look out for, I'm all ears. I think the rear seal is leaking too but I'm going to leave that one to my mechanic.
