George B
¯\_(ツ)_/¯
Take a close look at the plugs for your cables on that tech2. Some of holes in mine had plastic molding flash that was down in them. Made for a flakey connection through the candi. I cleaned em all carefully with a pick.
I'll def check that out. I didn't use the candi module tho.Take a close look at the plugs for your cables on that tech2. Some of holes in mine had plastic molding flash that was down in them. Made for a flakey connection through the candi. I cleaned em all carefully with a pick.
So I did the crank relearn today.View attachment 264689
I wasn't able to test it out yet.
I keep getting this too.View attachment 264690
Annoying AF!
Changed the rear taillight bulbs out to the regular bulbs. Cleared up the 3rd brake light from coming on with the other lights. Thx @Rocket Man and @George B for the suggestions.
I just noticed how bad the roof got.View attachment 264691 View attachment 264692
True, true. I'm under 6' so it won't bother me--unless I stand on my front porch and look at it!The good news is it's only bad on the top![]()
Never look down on the hoe.True, true. I'm under 6' so it won't bother me--unless I stand on my front porch and look at it!
Solid advice.Never look down on the hoe.![]()
I saw that too. This pig is mentally and financially draining me--makes my butthole hurt!Might also be time to think about new sway bar links.
