Very touchy gas pedal
Jeff Groves
Retired Demo Expert. I don't need to run anymore!
Nevada, Ohio
The 2001 Tahoe has a VERY touchy gas pedal from a stopped position.
I'm thinking a stronger spring would solve that?
Jeff Groves
Jeff Groves
Nevada, Ohio
Is it sticking? otherwise maybe a spring broke.
It does not seem to be sticking. It's just very touchy when taking off from a stop. I'll be able to check the linkage today.
mountie
I just bought my 2005 Yukon 8 months ago.... As I cross the intersection, the road has some bumps. My foot moves when I run over the bumps and my peddle is also sensitive. I have to learn to be careful.
I am wondering if I can put some resistance to the peddle.....
I have the same issue.
Jeff Groves
Jeff Groves
Nevada, Ohio
I found out I have Drive by wire? So not sure yet how to fix my issue unless I can do something to the pedal itself.
I like a snappy pedal, my 03 Silverado is like that sometimes if you just tap the pedal she want's to do a burnout, I have to warn anybody else that drives it that she's feisty lol, but what people do sometimes is put zip ties on the cable down at the pedal to take out any cable slack, you might want to just take a peek down there and see if that is the case, if so you can just take them off.
Jeff Groves
Jeff Groves
Nevada, Ohio
Checked the pedal. There are 2 springs on the Drive by wire pedal. NO cables at all.
I believe I can change the one spring with a bit stronger one to tame the burn out take offs.
Will have to remove it to get data then it's just order stiffer springs from McMaster-Carr to try.
