If I do it I'll definitely be doing the 99-07 duramax package from Glowshift. 3 pods of your choice and the pillar is basically free. I'll probably do narrowband AFR, trans temp with their 4l60e stub sensor and volt or water temp.
Glowshift is nice stuff, just a little pricey.
Fless
Super Moderator
Elev 5,280
So I had my t-case serviced last week. Since then, it’s making a really loud clunk noise, both shifting in, and out of 4lo. I don’t expect silence, but it’s definitely louder, as it was very quiet before the service was done. I know there’s not much to it. Just a drain/ fill, and I know the correct Autotrak fluid. Not sure why this would be making so much noise now. I also noticed the switch on the dash will show it’s in neutral even when it’s not on occasion. Thinking the actuator May be on the way out. Thoughts?
@Sam Harris, my NVG246 (NP8) has a very distinct (read: loud) clunk when shifting in and out of 4lo, and it's always been that way, even before the rebuild. The dash light thing happened to me maybe a year before the TC was rebuilt; I'd be going down the road and the switch would suddenly show "N" but I'm still getting power to the wheels. Pulling over and turning the key off and back on would usually correct it for a while. Replacing the encoder motor fixed that, so that would be my first guess. You could check to see if they got the bolts tight on the encoder motor.
The dash switch can be removed and ohmed; if you need that info let me know and I'll post it or reply to a PM.
Sam Harris
Texas
Great information! Thanks very much! That’s exactly what I do when the neutral light comes on. Sounds like I need an encoder motor then, or at least check the connection. [emoji106][emoji16]
Fless
Super Moderator
Elev 5,280
For a TC fluid change they wouldn't have necessarily done anything with the encoder motor. However, to pull the encoder motor you'll have to pull the front propeller shaft (driveshaft) out of the front diff u-joint and from the TC splined shaft.
I have a Tech 2, recently purchased, and have done a bit of testing but am not all that familiar with it. Happy to make it available to you since you're in the area.
Sam Harris
Texas
Thanks so much! That would be great!
ashleightx28
