NoReverseYukon
NE Wisconsin
Gonna tackle the water pump tomorrow. Thinking about draining the block at the same time.
What can I expect difficulty-wise in getting them out? And Haynes says there are 2 while some DIYers claim 4. The engine has 330K with unknown service history. Will I find a lot of sediment?
Should I bother, or not?
Thanks.
BaMaDuDe87
Bama
Okay maybe not the right thread, but app is everyone using for OBD readers for iOS?
Thanks.
Depends on if you have rust or not I suppose. There’s 4 bolts. When I did mine at 150k it was super easy, no sediment just Dexcool. At 330k who knows.
Fless
Super Moderator
Elev 5,280
Thanks.
By "getting them out" do you mean the block drain plugs?
Dantheman1540
Sugar Loaf Mountain
By adding that filter, wouldn't you have to change it every so often cause it'll clog up.
Yeah, I'm sure it will but it's just for temporary testing purposes. It's a glass cleanable filter like I typically put on my carburetted engines. I can run it for 1 tank of gas and inspect. If it's really bad I will add a different style mesh to the can and retest. It's very likely I'll never be able to catch all the oil just by changing mediums in the can but it's fun to test and doesn't cost anything.
Fless
Super Moderator
Elev 5,280
Yes, the 17mm block plugs.
Cool, I wasn't clear on that. Haynes says one on each side of the block, and you may need to use a poker of some sort (book says Phillips screwdriver) to break a possible crust once you get the plug out. I think doing at least one of them would be worth it if they come out easily enough.
